train man wrote:
Ok so here's the install:
I mounted the compressor under the hood on the passenger side next to the radiator. To do this I removed one of the headlight assemblies and the battery and battery pan. This gave me room to work.
I also mounted the solenoid valve under the hood I put it inside my truck's under hood storage box a handy feature GM used to put on their trucks(not sure if they still do)
They do on the light trucks - I have a 1-ton and it had an empty battery tray there waiting for the second battery. Which I promptly made non-empty. Only a Group 24DC, not enough room for a 27DC. (Darn.)
But there are enough nooks and crannies to mount the compressor and solenoid in most trucks, and it is weather resistant enough for the use. The only thing you might want to add is the plastic anti-short boots over the power terminals.
train man wrote:
The tank is 2.2 Gallons and I can get probably a good half a min. of honking in on it if the compressor switch is turned off but with it on it's hard to run out of air because the pump makes air at a little higher rate than the horn uses it. the sound does get a little weaker but not much! Ok so the tank is mounted under the bed in front of the spare tire. the pressure switch on it is set at 120 PSI. and it kicks on at 110 PSI
If you have the compressor wired directly to that little Hobbs style pressure switch, you should add a power relay in between. As far as I know those small switches are only rated for an amp or two, for a warning light and buzzer.
And larger tanks are available from truck air brakes. 6 and 12 gallons, if you have the room to mount them.
train man wrote:
In the cab I have a few blanks on the dash so I used two of them one for the horn button and the other for the compressor switch( used to turn the compressor off when the engine is off because if it happens to kick on when the engine is off it will kill the battery in a hurry!
The little black button on the very top up above the cargo lamp switch is the horn button and the toggle switch on the bottom left is the compressor switch.
You can wire a toggle switch so the stock horn button honks either the stock or the air, but this is NOT recommended if anyone else ever drives the vehicle. If you leave it in the wrong position...
I'm going to rig mine with a good old lanyard valve/switch over the window. then when you reach up and grab for it there's no question that you wanted to make a big noise.
train man wrote:
Now the horns! I mounted them on the drivers side under the cab (directly under my seat to be exact) I had some extra horn "shower caps" (used on locomotives to keep birds and stuff out of the horns) laying around so decided to put them on the horns to keep road grime and rocks out of the horns.
Ooh! Who makes those?
--<< Bruce >>--
